メインコンテンツにスキップ
シンプルな35mmマニュアルフォーカス一眼レフカメラ。 型番X-370。
Why won’t my camera turn on?
I recently bought this camera at a local thrift store and got some film for it but was disappointed to find that when I put new batteries in the camera would not turn on. No lights on the viewfinder. No shutter click. I’ve researched a bit and the capacitor was a problem for some people and the symptoms were the same but it looks like someone has already replaced it and it has no wear. I’m beginning to thing this is a problem with the wiring but I wanted to double check that I haven’t missed anything stupid.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi @kai_ ,
Not implying anything but.... ;-)
Have you verified that the batteries are installed correctly and that the camera's battery terminals are bright and shiny and that there is enough tension being exerted onto the batteries to ensure that there is a good connection?
Here's a link to the User Manual, scroll to p.9 to view battery installation and type information
Update (04/17/2018)
Hi @kai_ ,
No.
Actually the 357/303 are silver oxide batteries and are reputed to last up to 4 x longer than the LR44 which are alkaline.
I don't know your camera but am just verifying that you installed the batteries correctly in "series" connection, That is +ve side of 1st battery up into the battery cap then +ve side of 2nd battery up, therefore +ve side of 2nd battery connects to camera terminal and -ve side connects to internal cap end (which should have a metal contact plate) when batteries inserted and cap locked down giving 3V battery. (See green arrow in image)
There is a battery installation picture in the battery cap which may show it better than I have explained, (shown by the red arrow in the image).
(click on image to enlarge for better viewing)
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
The battery’s I bought are 1.55v energizer 357/303. That’s what the worker where I got them said to get instead of lr44’s but they don’t say they can replace lr44’s. Do you think that’s the problem?
さんによる
コメントを追加
回答を追加する
Kai Hagen さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 46
今までの合計 10,266
