メインコンテンツにスキップ
Repair guides and support for LED, LCD, HD and other Vizio TVs.
931回答 すべてを表示
Can you resize the info window?
I have had a 55" Vizio for about 10 years and have absolutely loved it. We recently moved and bought a 50" Vizio. The info bar on the new TV is so small we can't see it. We can barely see the channel it is on or the info about the show. Is there a way to make that larger like the older TVs?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
6 件のコメント
Hi @kreeves11674 ,
What is the model number of the TV?
さんによる
It is a D50-E1
さんによる
It is a D50X-G9
さんによる
If you don't mind the zoom picture it also works on the text
Not the best answer but the only one I found
さんによる
Same issue can barely see the Channel number it's so small. Can't you do a software update and fix this?
Model # D40f-G9
さんによる
1以上のコメントを表示
コメントを追加
4件の回答
最も参考になった回答
Hi @myextra99,
What is the signal source of the TV?
Is it from the antenna or from a “box” of some description?
If from a “box” have you checked the settings in the box to ensure that things like aspect ratio and other settings that affect the picture are OK?
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
From an antenna direct to the tv
さんによる
Hi,
The user manual - see p.20 does not show the options but have you checked in the Picture Mode Edit setting menu to see if there are any settings that allow you to resize what is displayed?
Has the problem always been there or has it just occurred?
If just recently occurred try resetting the TV back to factory default and check the result. See p.37 of the manual
さんによる
I checked the picture mode and nothing that worked. I just got the tv a couple weeks ago and probably should send it back if it was not so much trouble. In factory settings it was as it is now, way too small. I checked other web sites and it seems there isn't a fix! Whoever designed it sure must have super power eye sight!!. Thanks for trying
さんによる
Hi,
Try contacting Vizio by email about the problem. Be polite but firm that this is not good enough.
Ask if there is a firmware update that may fix the problem or if the problem can be passed onto their technical department or if their technical department can contact you about it
Vizio states that the TV firmware is updated via the internet using settings in the TV (there are no longer any manual updates by downloading and installing it yourself) which doesn't help if the TV is not connected to it.
I've found that a lot of companies respond better to emails, because they have to reply in writing rather than if you contact their customer service by phone where it appears that you are being fobbed off.
If they don't respond positively, return the TV and get another brand.
If enough people did this they might get the message.
Good luck
さんによる
コメントを追加
Hi @kreeves11674 ,
Can only suggest that you check that the aspect ratio for the TV is set to Normal (p.36 of the User Guide) and failing that try restoring the TV to its' factory default settings (p.38 of the User Guide - take note of the warning if you go to do this).
Here is a link to the User Guide for the TV.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi kreeves, try turning on the zoom mode, it enlarges the text on the channel, so u can see the info better on the channel.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
There is no fix. It’s built in. Zoom doesn’t work, factory reset doesn’t work
Here’s my fix. Move recliner close to tv!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kevin Reeves さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 63
今までの合計 7,360
