メインコンテンツにスキップ
モデル番号 A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7プロセッサ
214回答 すべてを表示
What type of paint is used to paint the bezel behind the LCD?
I’m wanting to find the closest paint to touch-up a scratch which occurred when removing the old display adhesive after performing an upgrade inside my iMac.
The mark is on the inside of the display which has exposed the pure glass which can clearly be seen on the front. It is small but still noticeable, I know that it probably won’t be restored back to what it was before I damaged it... I’m just wanting it to be less noticeable.
Thanks for any help or advice!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
The type of paint used to paint the bezel behind the LCD can vary depending on the specific device and manufacturer. However, in most cases, a type of paint known as "plastic paint" or "plastic primer" is commonly used for painting plastic surfaces, including the bezel.
Plastic paint or plastic primer is formulated to adhere well to plastic surfaces and provide good coverage and durability. It typically comes in aerosol spray cans for easy application. You can find plastic paint or primer specifically designed for automotive use or general-purpose plastic paints available at automotive supply stores, hardware stores, or online.
Before applying the plastic paint or primer, it's essential to properly prepare the surface by cleaning it thoroughly and removing any dirt, oils, or previous coatings. Lightly sanding the surface with fine-grit sandpaper can also help improve the adhesion of the paint.
When applying the plastic paint or primer, follow the manufacturer's instructions regarding the recommended distance for spraying, number of coats to apply, and drying time between coats. It's important to work in a well-ventilated area and wear appropriate personal protective equipment.
By using a plastic paint or primer designed for adhesion to plastic surfaces, you can achieve a durable and long-lasting finish on the bezel behind the LCD.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Kalan Howse さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 65
