メインコンテンツにスキップ
Seventh generation laptop released in 2015. The Alienware 17 R3 is a high performance gaming laptop.
How to remove head phone jack from alienware 17x r2
the head phone jack got broken with part of it left in
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
iFixit sells a tool which can remove broken headphone jacks. It's called the GripStick, and you can find it here: GripStick Headphone Plug Extraction Tool
This is designed for professional repair techs who have become familiar with the process over time, so it can be tricky to use at first. Occasionally, the GripStick needs to be pinched slightly near the tip in order to fit, but they do require a bit of skill and finesse to use them successfully.
Please note that the GripStick does not have any warranty whatsoever, so there's no guarantee it'll remove the broken bit in your computer, and no returns are accepted.
GripStick is a tool designed to easily remove broken 3.5mm headphone plugs from jacksの画像
製品
$24.99
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
gaary8354 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 250
