My ipod is locked and I forgot the password
I need help unlocking my ipod touch
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If you connect it to the same computer it is "paired" to for syncs, you can force the pass code off:
You will, of course lose any content which has not synced back to itunes from the iPod...
See also Apple's tech note on this.
このアンサーは役に立ちましたか?
David Iwanicki's fix also works if your Ipod is stuck in a loop it is step 4 that saved my ipod 32 gig
now i got one more to fix
Works 100%, thanks
thanks alot great
Thank you so much, I goggle on how to unlock iPod touch this was best answer by far, I looked like a pro to my son and became the hero :) thank you again.
it is not dislaing the passkey part it says that i connect to itune
You may get the solution from here: https://discussions.apple.com/thread/490...
このアンサーは役に立ちましたか?
try putting wrong password first then hold the lower left button for 5 seconds, then press 3 and hold the lower left button for 2 seconds and repeat... and afterwords when it says wrong password press cancel a message will come up and it will tell you your password is — — — —. (ONLY WORKS FOR IPOD 3G,4g AND IPHONE 4 NO IPOD C OR Cs OR IPHONE 5,5s,6 or 6s
このアンサーは役に立ちましたか?
what button??
Restore/ renew from iTunes
It’s not rocket science
このアンサーは役に立ちましたか?
Except iTunes is a nightmare to navigate 98% of the time
過去 24時間: 2
過去 7 日: 15
過去 30 日: 66
今までの合計 147,293
Sankaraperugu
Abhinay Perugu さんによる
