The battery door is broken, how can I replace it?
The battery door is boken, I need to replace.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Is it the door itself or the hinge that's broken?
Probably the best source of spare it to look out for the same model on eBay advertised as "spares or repair" and cannibalise the door. Assuming the hinge is ok you'll probably find you can remove the door from the hinge just be undoing a couple of screws, and hence fit the replacement.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 678
