メインコンテンツにスキップ
Released Quarter 2, 2014. Identifiable by Model Number: HBS-750.
11回答 すべてを表示
Why can't I hear the music on both side of my earphones?
I had this pair of earphone since Christmas and has been working fine, but all of a sudden I cant hear the music, I checked everything on the device the Bluetooth still connects to my phone and charges well, but I have to move the wires around and you can hear a faint sound but has to be in a certain position, I was told to open up the earpiece but I have no way too open, need help!!!!!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Please how I fix the problem of not hearing my callers but they hear me? Please i need urgent answers. Thanks
さんによる
コメントを追加
1 件の回答
ベストアンサー
Typically, when you have to move the wires around to hear the sound. It means there is a bad wire connection between the speaker and the amplifier in the earphones. There is pretty much only two ways to fix this problem. The first is to tear down the earphones and try to manually reconnect or adjust the connection. The second is to just end up buying another pair.
Best Regards,
Drew
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I see, but the problem is there is no way to opening the earpiece and even tried using a razor to cut my own way in. but yet no luck, any recommendation??
さんによる
This guide I attached below may be of help to open the earpiece. It is not my guide and I have not ever used these earphones, but I am trying to help based off previous knowledge and experience.
Best of Luck,
Drew
LG Tone Pro HBS750 Magnet Replacement
さんによる
コメントを追加
回答を追加する
LelandAnagal さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 20
今までの合計 1,327
