メインコンテンツにスキップ
The Acer Aspire E 14 Touch can be identified by its model number: E5-471-5456. The device was released in late 2014 and has a 14 inch HD LED-backlit TFT LCD display, a NVIDIA GeForce 940M GPU with 2GB DDR3 VRAM,  as well as an intel core i5 processor with 2.2GHz.
7回答 すべてを表示
acer aspire e5 471-35sl no power
my laptop acer aspire e5-471-35sl bios flash and now power is not open .not charging
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
First of all, try removing the battery and turning it on with only the powersupply plugged in.
If that doesn't work try to insert the powersupply and wiggle it a bit, if it feels like the part that the powersupply is plugged into (the dc connector) is loose or follows the power plug without resistance to the wiggle, it will probably need to be replaced or resoldered onto the motherboard.
If neither is an issue you might have to open up the laptop and take out any removable hardware and periodically try to power it on. if you get to a barebones motherboard with not poweron then it is probably the laptops motherboard that is defective.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ko latt さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 658
