メインコンテンツにスキップ
2.26 or 2.4 GHz / White plastic unibody enclosure
645回答 すべてを表示
My laptop is being strange..
I need help. My laptop keeps clicking and making weird buzzing noises and won't start. If I restart my Mac, the screen is plain white while the noise goes on in the background. The Apple logo appears and loads a bit before it stops loading. I've tried off of another forum the dusting thing for the noise but the screen won't load. It was working fine yesterday, I left it on and inside of my bag along with my VR headset. I didn't use it yesterday and when I tried to use it today, the screen froze on my discord app and when I restarted it, the clicking noise happened along with a buzzing sound. Now there were debris on my laptop from the bag, I believe I had crumbs in there. Maybe it's the temperature? It was really cold last night and today. I've restarted it 4 times and left it running for a few hours before the clicking gave me a headache. Can someone please help me?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Your hard drive has gone bad. The clicking is caused by that read arm going back and forth searching the drive.
UPDATE
You had the wrong machine selected. I have changed it and here's the guide:
MacBook Unibody Model A1342 Hard Drive Replacement
To repair it you will need:
Tools
Phillips #00 Screwdriver
T6 Torx Screwdriver
Your machine will take
Pre-Installed MacOS: X 10.6.1 (10A2047) Maximum MacOS: Current*
After you replace the drive you may be able to do an "Internet Install".
https://www.youtube.com/watch?v=6O07buFQ...
Also you can get a Snow Leopard retail installation and follow these directions:
https://support.apple.com/en-us/HT3910
このアンサーは役に立ちましたか?
スコア 6
18 件のコメント:
Is that why? Hm. When I unscrewed the back I did hear the clicking near a hard drive or memory drive that said Toshiba and it was rose gold. Is that the hard drive?
さんによる
Did you pull the drive following the instructions? If so try restarting using the original system installation disk and you should not hear the clicking anymore. If you do not have the original disk, you can use a retail 10.5 or 10.6 disk. Use Disk Utilities to format the new drive and install a new system.
さんによる
My mother bought this laptop from a neighbor so I don't have the disk. And my screwdriver isn't small enough to get the screws keeping the hard drive down. But the rose gold Toshiba thing is the hard drive right or is that the memory drive? Beside that was the big black battery.
さんによる
I believe you have selected the wrong machine by your description of what you are seeing. Look on the back and see if you can find a Axxx number or an EMC number.
さんによる
Is there another way I can get the hard drive to stop?
さんによる
13件以上のコメントを表示
コメントを追加
回答を追加する
Hiroshima Kayama さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 138
