dishwasher does not heat
replaced the heating element and it still does not heat
Cause 1
Heating Element
Some dishwashers use a heating element to heat the dishwasher during the drying cycle. If the heating element has failed, the dishwasher won’t dry dishes properly. To determine if the heating element has burned out, use a multimeter to test it for continuity. If the heating element does not have continuity, replace it.
Here's the part for your machine, thanks for providing the model number ;-)
このアンサーは役に立ちましたか?
I have replaced the heating element and it still dos'nt heat
Hi @Fritz Mehrer,
Just wondering if the Hi Limit Thermostat may be faulty preventing the heater element from being turned on.
The page tells you how to test it.
Located as part #F29 from this page
過去 24時間: 1
過去 7 日: 7
過去 30 日: 9
今までの合計 1,381
