How To Replace Just Glass on ZTE Zmax Pro Z982
so i shattered my phone screen an ordered just the glass replacement someone help or do i have to order the screen and digitizer??
Hi,
If you haven’t got equipment to do glass only refurbishment, it is highly recommended that you order a full display, as most phones these days have the display and glass/digitiser fused. :-)
このアンサーは役に立ちましたか?
The glass and the LCD display are two different parts on this phone and can be replaced separately. The digitizer is built into the LCD, so if you only cracked the glass in front don’t order the $40+ dollar full LCD assembly. You can order just the glass on Amazon. A warning, though, replacing this can be difficult. A good option would be to look up some videos on Youtube on how to replace the glass and decide from there whether or not you want to go through the trouble, otherwise most cell phone repair stores will still work with you if you bring in your own replacement parts, it will save you a few bucks doing it this way.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 8
今までの合計 1,829
