メインコンテンツにスキップ
The Mercedes-Benz W126 is a series of S-Class automobiles manufactured by Mercedes-Benz between 1979 and 1992. Premiering in September 1979 as the successor to the W116 line, the W126 was the second generation to officially bear that prestigious designation, an abbreviation for the German Sonderklasse or "special class." The W126 was initially offered with straight-six, V8, and a turbocharged diesel engine for the sedan. A C126 2-door coupé versions was introduced in September 1981.
9回答 すべてを表示
締切られた回答
Car stalls when throttle is applied after stopping
The car starts up fine. Every time i come to a complete stop and try to go again the car stalls out. It starts back up almost immediately every time. The only solution i have found is to let off the brake after stopping to start rolling forward and wait a second to give the car throttle. I have replaced both fuel pumps and the fuel filter but it didnt solve anything. Could it possibly be the fuel injectors? Im not sure what would cause it to stall out only when accelerating from a complete stop
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Petrol or Diesel
さんによる
It is Petrol
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Is there chrck engine if its a 94 or lower then prpbably not maybe a dirty maf sensor or leak somewhere in the air hoses
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 3
今までの合計 289
