usual SD card will not go in slot.Could something be blocking?
I have successfully used the card before now it only goes into the slot halfway. I do not see anything in the slot
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Try rotating the card 180 degrees and inserting it. It will only go in one way.
このアンサーは役に立ちましたか?
I have the same issue, it's not the way the card goes in.
I got it from a pawn shop. Can't tell if there is an old card broken inside, or if the popup housing might be broken.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 5
過去 30 日: 6
今までの合計 421
