メインコンテンツにスキップ
2017年3月に発売された第5世代iPadのWi-Fiのみのモデルです。9.7インチRetinaディスプレイと64ビットA9プロセッサーを搭載したモデルで、32 GBおよび128 GBのストレージオプションがあります。
98回答 すべてを表示
Is a loose home button after screen replacement "normal"?
I took my device to a third-party repair shop today and had the screen glass/digitizer assembly replaced. Afterwards, my home button was very wobbly and had lots of play. The store rep said this was "normal."
Am I crazy to think that it is possible to firmly reattach the home button after replacing the screen? I asked them to tighten things up but they refused, saying there was nothing they could do.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Properly securing the Home button bracket and insuring it isn't bent in such a way to leave extra space between the actuator and the bracket is an important part of the repair. Also replacing the Home Button gasket will insure the button doesn't flop around. Check out this repair guide to see how it is supposed to be like.
So yes, it is possible to do the job right but I suspect that the shop doesn't want to have to open up the iPad again.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Luc Mainguy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 2,433
