メインコンテンツにスキップ
Pi-top is a modular laptop you build yourself. It’s a tool to help you start learning how to code, create devices, and expand your knowledge.
Where to get a Replacement Screen for the Pi-top v2
Where should I get a new screen for the Pi-Top?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
I also have a Pi-Top V2, an became very frustrated when the screen blacked out intermittently.
I found that the screen bezel could be snapped off with no damage. It not easy, but not that hard. I used a big, sharp knife in the tight gap around the outer edge to carefully pry the bezel up, all the way around.
When it was off, I pushed the spot at the bottom of the screen where the flexible cable connects. Screen has worked reliably since then !
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hello,
Try sending a mail to Pi-Top support. They gave me replacement parts for free.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Joseph Wallack さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 8
今までの合計 942
