メインコンテンツにスキップ
The TJ series of Wranglers from the years of 1997-2006.
19回答 すべてを表示
How to repair reverse switch on automatic 2001 Jeep TJ
My reverse lights dont works on my Jeep trying to replace the switch but I can't locate it for an Automatic transmission, All guides I've found are for Manual transmission. Any help will be welcome
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
If you have the 4sp auto 42RLE then the only switch I can find relevant is the Transmission Range Switch.43RLE Bottom left picture switch number 3. Again called a TRS. The other two are input and output switches.
If however it is the 3 speed auto either the 30/32RH unit then it is a 3 pin neutral/safety switch. location
That might look something like this, 3 pin
Edit:
Based on that location picture, I think we are looking at an upside down view of the tranny. As that looks a lot like the edge where the pan sits. So I'm going to say left hand side, lower.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I believe mine is the 3-speed so where of you start to look is the location from that diagram?
さんによる
コメントを追加
回答を追加する
John Dooley さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 23
今までの合計 1,983
