メインコンテンツにスキップ
panic kernal on 5 out of 6 hard drives. Can they be fixed?
Can these hard drives be repaired ?
2 layers of text when using an install disc.
bottom layer says shut down & restart.
top layer has endless scrambled text with isolated words, i.e. panic & code interspersed within the text
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
That many hard drives failing with a kernel panic indicates to me that your problem lies elsewhere.
When you boot from the install disk with no hard drive in what happens?
Is this a retail system installation disk? What system is it? Is it a machine specific "grey" installation disk and what system is on it and what machine does it say that it's for?
UPDATE
Pre-Installed MacOS: X 10.3.7 Maximum MacOS: X 10.5.8
There are other ways to format than Disk Utilities.
Here's How to Erase a Disk from Command Line in Mac OS X:
http://osxdaily.com/2016/08/30/erase-dis...
Here's how to use Terminal:
http://smallbusiness.chron.com/format-os...
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
One hard drive did boot up properly with the retail disc that I used.
I have accumulated gray discs & retail discs with the leopard (not snow leopard) with similar results.
By the way, Mayer, you have the best track record on this site.
Thank you for your time.
さんによる
コメントを追加
回答を追加する
Dan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 7
今までの合計 56
