メインコンテンツにスキップ
PS3に同梱されているコントローラーの修理とサポート。 2008年半ばに発売された6軸リチウム電池式コントローラー(CECHZC2)は、修理が簡単です。
157回答 すべてを表示
How do I know which replacement button ribbon film to purchase?
I am looking to replace the button ribbon film in several controllers that don't work due to liquid corrosion on the film's connection point to the controller board. I have noticed several differences in button conductive ribbon films that are available out there. How do I know which ones I need to purchase? Are there differences internally in some Dualshock 3 controllers?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
hello,
I can understand your situation now as I meet the same problem like you.
may I know where you are buying the item ?
many thanks
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
EBay. I have seen as many as 4 different styles of film available from parts sellers. The looks are all similar with slight visual differences due to different manufacturers. The main reason why I'm concerned there is a difference for specific controllers is the fact that there are differences in the film's connection points to the controller board on all of the available film's.
さんによる
ok, I've got your idea.
さんによる
コメントを追加
回答を追加する
Joshua B Lambert さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 128
