2014 Civic LX Why is my ABS SRS VSA Powersteering lights on
2014 Civic LX CVT: ABS SRS VSA Powersteering lights on. $@$*!& ebay OBDII no errors or logged errors.
Car is in New England (cold winters snow and salt on the roads) but super warm days 40+ lights go off some times.
1/09/18: installed Philips 9006 CrystalVision Ultra bulbs (no error lights)
1/12/18: installed factory skid-plate not sold with car (no error lights)
1/24/18-2/1/18 (Error lights On)
2/2-2/4 Car not driven
2/5 40 degrees out sunny (lights off all day)
2/6 (lights back on)
What I've tried: 2/12/18: Battery tester said 70 charge after driving 45 mins on highway: Bought New Diehard battery 51R
2/20/18: Unplugged battery terminals and touched the wires together to reset ECU (lights off for 1 min then when I started driving all came back on)
2/21/18:Lights on in morning drive to work. Left work 5PM (not using headlights, radio, bluetooth) 70 degress out lights off!
2/22/18: morning 40 degrees lights came back on
2/22/18-3/26/18 stock lights back in (no success) lights on
Have you checked power steering fluid levels? Have you checked brake fluid levels? Have you checked your tire pressure?
S W さんによる
Yes. From what I have read about gen 9 and 10 civics it is a voltage issue. When the voltage dips to low all the lights come on like a Christmas tree. Not sure where to start with this. Ive heard about issues with the ABS wiring. I'm even having trouble finding the wiring part online that hooks up to the ABS if that even is the problem.
zebocrab さんによる
From your post of times and when the lights are on, sounds like temperature issues. You are sure your anti-freeze is topped off?
S W さんによる
