Why does the printer drag other white sheets and then lock them?
The HP 1320 printer is connected to the PC via USB. Windows 10 as an oparative system. When I print the printer, drag other sheets and lock. Other times it prints other white sheets. Manual two-sided printing from the front drawer, however, works correctly. I have updated the drivers, changed the PC, changed the operating system: the result does not change. What can it be? Thank you.
Are you saying when, that sometimes when you print it drags other sheets of paper through with it. This then locks up your printer?
sm_vulkus さんによる
Yes. When I print:
1 - a white sheet or, sometimes, correctly printed, comes out
2 - a second white sheet gets stuck in the upper part
3 - a third white sheet gets stuck in the lower part (just drawn from the tray)
4 - the printer stops
5 - the central LED flashes
see the b&w photographs
Lore さんによる
[image|1378795][image|1378797]
Lore さんによる
