メインコンテンツにスキップ
Repair guides and information for the HP 250 G3, a budget laptop released by HP in 2014.
28回答 すべてを表示
power button not working for booting.. but opening lid does?
My HP250 power button won't turn it on but instead works for forced shutdown or hibernation/sleep purposes only. the only way I'm able to switch on the laptop is to remove all power sources that being the battery or adapter cable then after I would close the lid and place back battery or adapter cable, when I open the lid that's when the laptop boots into windows. I have also resorted to force shut it down because every time after shutdown it automatically restarts.
what could be the cause of this ?
I have already tried a couple of those electrostatic discharge methods for the power button to work.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Try to reset Bios to factory default, and then make a bios upgrade...
If not help then , is a good chance that might be a hardware failure, may a bad small capacitor....
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
arnold charamba さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 6
今までの合計 566
