メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Device repair information for the 1080p 60" Projection TV by Mitsubishi with model number WD-60737.
Why wont my tv screen come on?
I have this tv . The volume works but the picture wont come on after like 3minn of leting the volume play the tv shuts itself off. why?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
6 件のコメント
on the back their should be a cord at the end its plug is a circle and in the middle theirs a pin make sure its in all the way and that the cord to plug in the wall is'int loss
さんによる
your answer was helpful.
さんによる
I’m getting a code 61. Six red flashes and one yellow. Any help??
さんによる
I'm geting a 61 code as well. But I'm getting 6 red 1 orange
さんによる
1以上のコメントを表示
コメントを追加
2件の回答
最も参考になった回答
cindythomas1370 check your LED indicators first and let us know what you find.
After that try to check the self diagnostics:
Update (03/23/2018)
SELF DIAGNOSTICS
To activate, press the front panel <ACTIVITY> + <CH down)> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit code.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is “23”, the LED will flash two times, pause, and then flash three times.
Note: The TV must be in “Shut Down” and the LED will probably be indicating an abnormal condition.
If the TV is switched Off, AC is removed, or a System Reset is performed, the code automatically
resets to “12” No Error. See the Error Code Log to retrieve a history of errors.
Note: Use the front panel buttons, not the remote control.
Note: If there is no response, the front panel may be locked by a V-Chip setting. To unlock, press and hold
<ACTIVITY> on the front panel for 5 seconds.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
your answer helped out alot it looks like it is the bulb.
さんによる
コメントを追加
I did the requested activity/ channel down button for [5] seconds. Code31 flashed.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
cindythomas1370 さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 25
今までの合計 1,951
