メインコンテンツにスキップ
Repair guides and support for wireless and wired Apple keyboards.
209回答 すべてを表示
Left Shift + E not working (Right Shift + E works)
Hello everybody,
I have a strange Problem with my second hand A1243 (With Swiss Layout) Keyboard.
If I use left Shift + E it doesn't do anything, but if I use right Shift + E it works.
Everything else works so far.
Has anybody any idea what that could cause?
Thanks in advance.
Sandro
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
did you spill something on it?
さんによる
No, I just got it second hand. Perhaps the previous owner spilled something.
さんによる
コメントを追加
3件の回答
ベストアンサー
Hello Everyone
Sorry for coming back to you so late and thanks for your inputs.
It started working again. But I’m not sure on what the problem was.
I have two possibilities:
1) Because of my work I’m using various softwares that have system-wide shortcuts (like Spectacle for window rearrangement). I have reinstalled some of them. Maybe these shortcuts for english keyboards had a binding that was not working with the Swiss keyboard.
2) Around the same time it stopped working, I have updated my Laptop. While uninstalling the softwares mentioned above, I updated the laptop again and also reseted the NVRAM/PRAM.
One thing that stands out (I don’t believe it was the problem though) is that the the bottom left of the chassis of the keyboard had a small bump in it. Between the alt and cmd keys. I flattened it out with my fingers but I don’t think this was the problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
Try left Shift for other purpose eg to Capitalize or other to check if it pressed.
If it is ok, you can change the keyboard layout in mac settings.
http://thetypingcat.com/howto/change-you...
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I testet every other Left-shift Combination with the keyboard.
The layout setting ist also in Swiss-German (I tried German too).
It happens only with Left-shift + E
さんによる
Strange! change it to English layout to check it. Also check it on another PC if it possible or check it on windows with boot camp or virtual machine.
さんによる
コメントを追加
I’m having this exact issue. The computer is a 27” iMac, the keyboard is an apple USB keyboard with keypad. It’s only the letter E, and only with the left shift key. I’ve checked the system preferences > keyboard > shortcuts area and I don’t see anything there.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Did you had luck with your keyboard?
As I mentioned above I updated the system, reseted the NVRAM/PRAM and looked at other software with system wide shortcuts.
さんによる
コメントを追加
回答を追加する
Sandro Ciotti さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 16
今までの合計 1,562
