How to fix my beanie boos noes
my dog ate my beanie boo's noes and I want to fix it but how?
Hey Casey,
Check out this guide. It has a couple different ones in it, but I think the most helpful for you would be to check the button one. Then, you can sew on a new button to your beany-baby's nose.
Hope this helps,
-Tanner
このアンサーは役に立ちましたか?
If it pulled it off, you can always try to sew it back on but if it chewed it up, you could always replace it with a small button or bead!
このアンサーは役に立ちましたか?
I have the same problem this morning my dog which chewing on my kitty OK she fell off the bed so I don’t wanna put a bead a bead button I can’t see her without her cute little pink nose I’m gonna see how much fabric Is left around her nose thenI’m going to try sewing it also liquid stitch which is what my mom is going to have to do
このアンサーは役に立ちましたか?
My dog ate at it but the nose is still on and she ate at the plastic piece
There are often Beanies at thrift stores and garage sales. You may be able to find a replacement nose on another Beanie being sold for a small price. The repair is a little fiddly, but someone who sews should be able to make the replacement. Of course, then there will be another Beanie without a nose… But maybe that is what some little bitty button is for.
このアンサーは役に立ちましたか?
You start with a double whisky neat, to reduce jitters. Go through your other, in tact, beanie babies and scavenge for better, in tact, appendages. Take said appendages such as a nose or arm and replace the &&^&@@ up appendage with the newly, in tact, appendage. Finish with another double whisky neat for a job well done, you deserve it!
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 10
過去 30 日: 39
今までの合計 2,159
5 件のコメント
Was it the plastic part only? Or did your dog chew off the whole nose (like the fabric and some stuffing)?
[deleted] さんによる
mine is the plastic part and i want to fix too i dont even have the piece
WrathfulSadness さんによる
Does anyone know where to find just the nose part?
strdms さんによる
Maybe u can use black stitch things to so it back
Momo さんによる
@WrathfulSadness mine was the plastic to, i was thinking we stich a black so to fix it
Momo さんによる
