interior fan not working, needs to be replaced, how?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@pa_pa_pa you do want to make sure that you check the fuses and the controller first. Then check the resistor block. Ultimately if it is your blower, use the attached part of the manual for the troubleshooting and the repair GC-HVAC.pdf
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 42
1件のコメント
Are you sure it is dead? Have you checked all your fuses and relays, and switches?
sm_vulkus さんによる
