メインコンテンツにスキップ
The Asus X200MA is a portable touchscreen laptop with an 11.6" display. This device was manufactured in 2014 and is also identified as Asus X200MA-RCLT07.
problem with touchscreen not working after unplugging and turning on
I've noticed recently that when I run my laptop on battery( or unplugged) and then turn it on the touch screen won't respond to touch anymore. Is there anything I can do to have touchscreen running from startup even if it is unplugged? The touch screen works just fine without the cord if I plug the power cord in, close the lid, then open it again before unplugging. But that is kind of a hassle and it isn't all the time that can plug it in to do so.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Hi,
If you have Win 10 installed try installing the latest Asus Win 10 ATK Package and Smart Gesture drivers.
Take notice of the Notes: near the top of the webpage regarding driver installation.
>>>>>> install the ATK Package drivers first before you install the Smart Gesture drivers <<<<<<
Do not be tempted to update any other drivers at this stage. It may confuse the issue if you run into problems. Solve one problem at a time. If it ain't broke, don't fix it!
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you very much. That did fix it.
It was like this on my previous laptop(same model) too before I accidentally dropped and broke it. I've been ignoring the issue for awhile on that one but since it popped up again on another laptop I'm glad there was a fix for it.
さんによる
コメントを追加
ASUS X200MA is a ClickPad, so it need the ASUS Smart Gesture. Check if there is a ASUS Smart Gesture on your computer. And you can view this article to see why your touchpad screen cannot work and how to fix it: https://windows10skill.com/asus-smart-ge...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Renus SP さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 898
