メインコンテンツにスキップ
The Tiida(Versa) hatchback and the Tiida Latio sedan debuted in 2004 in Japan, and in select European countries in 2007.
Will Not Accelerate Replaced Solenoid
My Nissan Versa 2009 will not accelerate . The solenoid was replaced got it from the dealership. By mechanic the car was reprogrammed and worked for a little with slow acceleration then seemed to correct itself the more I drove. Parked it for two hours then went to drive it again and it would not work again. What can be wrong with my car ):
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
@reinavia what solenoid was replaced? Have you had your Nissan scanned? Did the OBD display any codes?
さんによる
Yes a bunch of codes were displayed . The mech ordered a whole solenoid pack from the dealer.
さんによる
コメントを追加
2件の回答
ベストアンサー
There are at least 40 Technical Service Bulletins TSB's for your year model. At least 3 of those are for your transmission. Seems to be that this car is a lemon.
But they relate to the reasons why your car doesn't accelerate.
Many TSB's
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
There might be issues with the car that remains unresolved by the previous owner. It would be a good thing if you can decode the VIN and see what you can find about its vehicle history. Might help you identify the root cause and address it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Olivia さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 30
今までの合計 1,651
