メインコンテンツにスキップ
モデル番号A1286、発売日 2011年2月/2.0, 2.2もしくは2.3 GHzクアッドコアIntel Core i7プロセッサ
586回答 すべてを表示
Trackpad Replacement not working
I recently replaced the trackpad in a 15" MBP - Early 2011 and it seemed to be working great. However, no its working very intermittently, sometimes it tracks as I would expect other times the pointer doesn't even move.
Any ideas? Is this trackpad defective? If so how do I return it and get a different one???
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Check to see if your battery is swollen. If you can't tell, remove the battery and start up with just the mag-safe adapter and let us know if the issues persists.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I replaced the battery as par of the repair. I completely removed the battery and replaced the trackpad because the brackets had become bent with the last battery swelling so large.
さんによる
Check to see if the old battery has bent upper case. Did you also replace the trackpad cable?
さんによる
Top case looks good. Yes, replaced everything. Battery, trackpad, cable, screws, brackets. Its very odd. Sometimes it works great, other times not so much. very intermittent.
さんによる
コメントを追加
If you're certain you installed correctly, assuming the part is from iFixit, yes, you can get a replacement for a defective item. iFixit offers lifetime warranty against defects for non-consumable items. Hope that helped! (If you have questions about iFixit returns, post them on meta.ifixit.com, not here)
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Thanks, I threw that last part in just as a, "if no one else has good options then I will need a swap" kind of comment. Thanks for the link though.
さんによる
@cssd11tech No problem! Hope you solve your issue!
さんによる
コメントを追加
回答を追加する
Jason Reynolds さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 125
