メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1778,1784。 GSM かCDMAの32、128、256GBがあり、色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラックがあり。
1364回答 すべてを表示
Is my iPhone 7 Plus worth the repair?
I had my cracked screen replaced on my iPhone 7 Plus about a year ago. It was done by a third party repair shop, not Apple. I had minor issues with the touch; nothing that I could not work with and ignore. It does tend to heat up doing minor tasks and especially with a cover (that I never had an issue with with my 6 Plus, and still don’t). Makes me think that there may be some hardware damage, but I am not sure. Recently, within the last two months, the screen started going black, with some pixels of white in a small line on the screen, but not in the same place each time. Then would go to the startup screen with the Apple on it. It keeps doing this when I use it. This phone is a lease and it’s about time to return it. My predicament is that I won’t be able to lease or finance another phone, so paying the $130ish to buy the phone and repairing it, may be cheaper than buying a new one (almost $800 for the same phone, not ready to get the 8 or X). It is a 256GB Rose Gold iPhone 7 Plus. Given the symptoms, should I even dare take it to Apple or another repair shop to see if it can be salvaged or is it not worth it? Thank you!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
Had you certainly just a screen problem, it would be worth finding a local repair shop that could replace the screen again and warranty their part so that you don't have to live with possible defects in the future.
However, since your phone possible had other issues, I recommend doing the more expensive Apple store screen replacement for the simple fact that they will give you a 3 month Apple warranty with the repair. That way if you fix the screen in March, you can return to them in April and claim that the phone is acting up. With any luck they will cost the simplest option for them and swap the whole phone.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you! Wouldn’t they notice the screen on it is not the original? By the part itself?
さんによる
コメントを追加
sell this and buy new.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have to purchase it first, but wouldn’t the problem make it harder to sell?
さんによる
コメントを追加
visit a trusted local repair store,explain your case, let them check your home button etc cause it shouldn't be heating up for sure so sound like damage, but the glitching is a screen problem so make sure if you do change get a decent warranty to void additional fees. if the button isnt damaged, go ahead get your screen replaced with a good warranty buy it out use it until your ready to sell or upgrade. If the home button is damaged, then theres some more money to get into so it would be your choice because you will probably be into between 200 and 400 if button is damaged just for repair plus the buyout fee.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Marnie Madnikoff さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 1,095
