メインコンテンツにスキップ
Android smartphone with a 5.15" 1080p display and a Qualcomm Snapdragon 820 processor. First released in 2016.
48回答 すべてを表示
Camera glass popped out
My phone is xiaomi Mi5 and recently camera glass is popped out but its not broken.
here is the picture of what happened :
Glass and phone
i still have the glass i just don't know how to stick it back !
can i use glue ?
if yes what kind of glue?
what things i should know before using glue?
what are other option other than glue?
Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
This is very risky, you could get glue on the lens but use an adhesive if you can find one, if not, then try a hot glue gun, but this should be a last resort, at this point contacting xaiomi to ask them what to do is probably the best idea
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
What kind of adhesive i should use?
さんによる
Well, idk, who knows, newegg has a lot of stuff on it, if you can measure the glass and find an adhesive with the same diameter, if you can't try a hot glue gun with a very small tip
さんによる
コメントを追加
回答を追加する
Ramin Dashti さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 4
今までの合計 182
