メインコンテンツにスキップ
The third-generation Nissan Sentra was released in 1990 and produced through 1995. From August 1992 production, the B13 received a facelift for the 1993 model year.
4回答 すべてを表示
wet and black spark plugs
l started noticing that the car was now lacking power, and when l checked the plugs. l realized they were black and wet. what can be the causes and how can l differentiate that the wet substance is petrol or oil?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Fouling plugs is a pretty common problem for a motor that has bad compression. Easiest way to figure out if it's oil or petrol is to pull the plugs out and wait about 3 minutes then touch them. If it's oil it will still be wet, if it's petrol it will have evaporated
このアンサーは役に立ちましたか?
スコア 5
コメントを追加
回答を追加する
xolani さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 11
今までの合計 4,049
