メインコンテンツにスキップ
Android phone from BLU, released September 2015.
9回答 すべてを表示
Headphones not picking up phone calls
Why is it that music works fine over headset whether wired or Bluetooth but when I try to make a phone call headset doesn't pickup anymore, again whether wired or Bluetooth. This feature is important to me and it used to work all the time.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @notbob ,
Are you using the 'phone' app to make calls or a 3rd party app?
If using the normal phone app, try starting the phone in ''safe mode'' and check if it works OK.
If it does work OK then a downloaded app is the cause of the problem. The trick is to find out which one.
If it still doesn't work try a factory restore, (also known as a hard reset), using the phone's factory restore feature.
Before you perform a factory restore, backup the phone first.
Be aware that a factory restore will erase all your data and downloaded apps. It will be restored to its' factory default condition. That's why it's important to do a backup first.
Once the factory restore has been completed, check if the phone works correctly. If it does then restore the phone, using the backup that you made earlier, using the phone's restore feature.
Once the restore has been completed, check the phone again to see if it is still OK.
if it is then the restore (reset) has fixed the problem.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Paul Newbert さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 212
