メインコンテンツにスキップ
モデル番号はA1199で2、4もしくは8GB容量
85回答 すべてを表示
締切られた回答
Ipod is not charging?
I think I have a IPod Mini. Not sure. The model # is A1199, 2 GB. The battery ran out,I bought a dock conn. cable and plugged it in. After several hrs., it shows "do not disconnect" and it has a red circle with line thru it. Should I do something else? thank you a Senior Lady. Claudia
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Your iPod may very well be charged -- the "Do not disconnect" notice may just mean that the iPod is mounted on the computer and thus should not be unplugged yet. Open up iTunes to see if an image of the iPod is in the left hand column. If it is, click on the eject button to the right of the iPod image (it's the circular button with the triangle on top of a line). Then the "do not disconnect" message should go away and you should be able to unplug your iPod. If that doesn't work, shut down your computer. When it's completely off, unplug your iPod.
With your iPod unplugged, you should be able to determine if it actually charged up.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 2,239
