メインコンテンツにスキップ
2009年6月発売、2.66, 2.8, もしくは3.06 GHz Core 2 Duo Processor
300回答 すべてを表示
No power on after keyboard replacement.
Hi,
I just finished up with replacing the keyboard on my A1286 15 MacBook Pro. Serial no. ending in 7XK.
After doing the keyboard replacement the device doesn't turn on however the MagSafe charging light indicates that it is charging. Any ideas as to what I could be missing? This is my first repair on a MacBook so I'm very new to this...
Thank you!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I manged once to get it to boot by unplugging the battery, holding the power button for ten seconds, then plugging the MagSafe in and continuing to hold the power button for another ten seconds. After which I let go and pressed the power button once.
It worked once but hasn't since then....
さんによる
コメントを追加
2件の回答
最も参考になった回答
You got am spontaneous rebooted by disconnecting the battery and mag-safe then reconnecting.
The first thing to check is the keyboard to logic board connector seating. See step #18 of this guide: MacBook Pro 15" Unibody Mid 2009 Upper Case Replacement
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
I've just reseated that connection and checked the cable for any snags or marks but still to no avail.
さんによる
Why were you replacing the keyboard?
さんによる
The command key, back space and S key didn’t work.
さんによる
I take it you spilled something on it?
さんによる
I bought it second hand, so I'm unsure whether it's been water damaged. I did have a good look inside the device and none of the LCI's are triggered. But who knows. It wasn't stated when I bought it.
さんによる
コメントを追加
sounds like you have a bad connection or missing connection. Go through and double check to make sure all cables are attached to the mother board correctly. did you take out the battery and ac adapter before doing the keyboard? if not it could cause a short on the logic board.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Definitely took out the battery and AC adapter before hand. The MacBook has booted since the keyboard replacement after an SMC reset but since then I haven't been able to boot it up again.
I'll double check over the connections tomorrow morning as it's getting late in the UK... I did do this once before though.
さんによる
コメントを追加
回答を追加する
Fraser McFaull さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 304
