メインコンテンツにスキップ
Rogue G10 10W 1x3.5 Guitar Combo Amp. A compact amp perfect for beginners or practicing. The Rogue G-10 guitar amp produces a variety of tones in a compact size.
3回答 すべてを表示
Turn on loud "Burb" then no Sound
I moved recently and my amp was in storage for several months (was suppose to be temperature controlled).
The amp is actually a Rogue 120 SC but though you could help.
When I turn it on there is a loud "Blaap" and then no sound.
Is it possible the speakers (2X12) are blown ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@scotia1 sure it could be the speaker. Just quickly wire another speaker to the existing one and see if it does play. However, I am always concerned with the audio IC. I would suggest that you take a couple of pictures of your circuit board and post those with your question so we can see what you see. Use this guide iFixitでの質問に画像を追加する方法 for that. Make sure you have a multimeter handy to measure a few things once we see what your amps board looks like.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jim さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 314
