メインコンテンツにスキップ
Appleによって製造された第四世代目のワイヤレスキーボードです。2015年10月に発売されました。モデル番号はA1644です。
Magic Keyboard 2 can not connect it via Bluetooth
My Magic Keyboard 2 can not connected via bluetooth, can only connected via usb, it just like dead totally after unplug usb cable.
Before this happened, I were cleaning it, and claped it a little bit, then it can not connected via bluetooth, usb is fine.
I wonder if the wire between battery and board is disconnected or something.
Is anyone knows what is going on ? Do I need to tear it down ?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
3 件のコメント
Did you clean it with a sanitized wipe? I've seen them cause liquid damage of keyboards.
さんによる
No, no water inside
さんによる
I have the same problem, I did not clean the keyboard, but bluetooth connection stops working, only works via USB
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi @kylebing ,
You may have 'bounced' the battery flex cable plug out of the connector on the pcb, when you 'clapped' it.
Here is a link to the ifixit Magic Keyboard Teardown guide.
Scroll down to Step.6 and hold your mouse pointer over the 3rd image to view the connector.
The guide is for the Magic Keyboard but hopefully it will be similar to your keyboard and this will still be of some help to you as you will have to open your keyboard to ascertain what the problem actually is.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks, I have opened it and didn't find the problem is. I think it is caused by the bad battery.
さんによる
コメントを追加
回答を追加する
Kyle Bing さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 37
過去 30 日: 81
今までの合計 7,797
