メインコンテンツにスキップ
2013年5月に発売されたXperia Lは、4.3インチスクリーン、8 MPカメラ、デュアルコアプロセッサ搭載のAndroidスマートフォンで、モデル番号C2104とC2105です。
20回答 すべてを表示
How to recover my Sony Experia L from turning off and on repeatedly...
I just want to post my problem about on My Sony Experia L, i was not able to use it since the night it started turning off and on and repeatedly... I dont think if the problem is my battery because its brand new and original... I hope i could get the best answer here...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Viens Semblante how old is your battery and why did you replace it? What was the problem that made you change the battery? Did your phone have those symptoms before you changed the battery?
さんによる
コメントを追加
1 件の回答
Good day, i just want to answer ur question, i used to brought new battery because i expect that if i would change my battery it will stop it from on and off repeatedly.... But i found out that its not the battery which is a problem anymore... Someone told me to re-start my phone, well i had search a lot of codes to re-start my Sony Experia L. but in the end i got failed, because after turning On my phone it was also automatically Off right away..
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yeah it had a symptoms before i changed that battery thats why i brought a new one, to think that its the only way to solve it, but nothing happens..
さんによる
コメントを追加
回答を追加する
Viens Semblante さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 188
