メインコンテンツにスキップ
Repair guides and support for your Samsung TV.
2614回答 すべてを表示
F-Series Vertical Green Line
Hey folks,
my F-Series Samsung (UE32F5570) got a vertical green line at a moments notice about a year and a half ago. About a half year ago I bought a new TV and never bothered about the old one until now. Okay so back to topic;
Is there any way to fix this TV without gambling or wasting too much money into it? I already opened the back of it and exchanged the ribbon connectors with each other on the T-Con board.
Oh and I removed both boards and baked them for 15 minutes at 200°C.
Kind regards
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hello Krypton,
You are getting a green line on the side of the screen due to a bad connection on one of the flexible ribbon cables attached to the screen itself. In the area near where the line appears you will need to gently press on one of the ribbons while the set is on and you will find 1 spot where the line disappears. To fix this you can add some sort of foam to constantly press in that area. That should be the fix for it. Unfortunately there is no other way to fix it short of replacing the tv.
Good Luck!
Rich Lilja
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
krypt0n さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 3,549
