メインコンテンツにスキップ
The Kia Sorento is a mid-size crossover SUV (mid-size SUV in its first generation) produced since 2002 by the South Korean manufacturer Kia Motors.
35回答 すべてを表示
Drain coolant, how catch in pan, is only a plug to remove, will drain
Need to drain coolant, how to catch coolant in a pan, is only a plug to remove, no fitting to attach hose to lead into a pan, will drain all over. ??
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
You probably will need to remove some of the plastic splash guard panel things under the front of the vehicle to drain the radiator effectively. Me I drained mine by running into a wild hog at 70 mph a couple of years ago.... Needless to say the radiator drained instantly, airbags deployed required a tow in. Car was totaled by insurance :(
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You remove the 1 piece splash shield, then radiator drains onto cross member and you clean up the mess. No alternative. Needs large catch pan. Messy.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
David Mallory さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 67
