メインコンテンツにスキップ
Water Spots on Screen, New LCD needed?
Hey, I spilt some orange soda over my 64GB itouch, and instantly went to flush it out with 90% isopropyl alcohol to get as much as I can off and out of any cracks or crevices. I successfully got the soda out, but some of the alcohol left these "bright blotches" on my screen. When reading on other forums, etc. I heard that it should evaporate and go away in a few days. It's been 3 weeks, and they're still there. If I open this up, could I let it air out or otherwise remove these markings? Or did I irreversibly damage the LCD screen?
I included pictures to show exactly what happened.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
2 件のコメント
Did u find an answer anywhere??
さんによる
Hi, do you find any solution for your problem?
さんによる
コメントを追加
2件の回答
ベストアンサー
The spots will not go away this is from water damage. If it bothers you you can replace it. I would wait until it fails or the glass gets broke to change it out, that way you dont damage the screen removing it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
First I would try opening up your iPod, and using a micro-fiber cloth to see if they will come off. If not, then you will need a new LCD which is not that expensive. Usually under $25.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Michael Dornisch さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,338
