メインコンテンツにスキップ
耳全体を覆うフルサイズのヘッドフォン、通称サーキュマル・ヘッドフォンの修理ガイドとサポートです。
108回答 すべてを表示
How do I disassamble JBL S400 BT headphones
I have a pair of JBL S400 BT headphones, where sound is not working in right side. I suspect it is just a loose connection. I have fixed JBL headphones before by just soldering a loose wire.
But I'm not able to see how I can disassamble these headphones. There are no visible screws. So I guess that they are some how clicked or glued together.
I have tried to twist the parts and also used a flat screw driver to force it apart. But it didn't work and I'm worried that I'll break something.
I have search for videos and images but have found nothing so far on this model.
Any ideas?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
I found this video: https://www.youtube.com/watch?v=nkxpm-_F...
And I was able to lift of the JBL lid by using a small flat screwdriver. The lid is glued, so it is not easy to remove and the screwdriver left marks on the plastic. Maybe some plastic tools would have done a better job.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Have you taken off the earmuff things? in a different model they are under the earmuff things.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks. I have tried to remove earmuffs. But no screws on that side
さんによる
コメントを追加
回答を追加する
Casper Skovgaard さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 10
今までの合計 2,846
