I pod not working
Hi My Device when open the ipod give white Display after out to main menu what i do it
mazenq, do you have any display? Does iTunes recognize your device? Have you tried to reset your device.
How to soft reset and hard reset your iPod Touch if it’s frozen or not responding.
Try a soft reset first:
1. Press and hold the Sleep/Wake button on the top of the unit until a red slider appears
2. Drag the slider.
3. Press and hold the Sleep/Wake button until the Apple logo appears.
If a soft reset doesn’t work, try a hard reset:
Press and hold both the Sleep/Wake button and the Home button, until the Apple logo appears.
このアンサーは役に立ちましたか?
Sounds like some sort of hardware issue. Try resetting and see if that clears the problem. If it persists, take it to your nearest Apple Store and have them take a look.
このアンサーは役に立ちましたか?
Thanks sir in my country dont have Apply store only shop normaly for sell
過去 24時間: 2
過去 7 日: 3
過去 30 日: 3
今までの合計 541
1件のコメント
mazenq, just to make sure I understand. Your display changes to white after the menu. You opened it to work on it? Is it an iPod or an Iphone?
oldturkey03 さんによる
