メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Xbox 360は、2005年11月22日に発売されたMicrosoft製第二世代ゲームコンソールです。
Repairing firmware
Do we have anyone with experience in repairing firmware? I have disassembled many, replaced bad drives or ports, etc. I am looking for any Xbox 360 lessons-learned, knowledge, help hints, and any information on "bricking" and "unbricking".
Your assistance is greatly appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
7件の回答
ベストアンサー
1 Red Ring is a general error
2 Red Rings is overheating
3 Red Rings is hardware failure (ususally a bad joint between the GPU and Logic Board)
error codes are ususally not easy to fix, there are error code keys on the web, but there are tons of error codes.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Lazer setting off.YouTube it.easy fix.
さんによる
コメントを追加
最も参考になった回答
ususally, xbox's don't get bricked, they have onboard firmware, and the firmware is not accessable externally, if you are trying to remove the NXE, it isn't possible, if you want to try, you may be able to trick the console into downgrading the firmware, by putting a firmware update file on the hard drive via special adaptor, but annother thing to know is that the xbox dvd drives are keyed to the motherboard that they shipped with, so if you get a new logic board, make sure that it comes with a DVD Drive
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Thank you very much for the information...I wondered if they were keyed. Any info on red rings (1-3), error codes, and RROD. I am still learning. Thanks, Kelly
さんによる
コメントを追加
i found this really helpful.
http://www.llamma.com/xbox360/repair/Xbo...
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Lots of good stuff here. +
さんによる
コメントを追加
These are the ones I use whenever I get to tinker with an XBox or just to keep mine alive. I do like xbins since it does have the proper software for remapping as well as firmware issues. Comes in handy....good luck.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Sorry forgot a few things :) http://www.xbins.org/
http://www.360-hq.com/xbox360/hardware/ that is what I meant to attach...
さんによる
コメントを追加
ok,my xbox360 starts screen freezes. scanable look. but with out hardrive it run disc fine. if idea.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
HDD Problem, try replacing it.
さんによる
コメントを追加
Hi Anibal my Xbox 360 not how open work happen know not
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Not work open each much time Xbox 360
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Not work Xbox 360 open not
さんによる
コメントを追加
回答を追加する
aquabluekt さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 23
今までの合計 6,619
