メインコンテンツにスキップ
2016年3月に発売された4インチのiPhone。ハードウェア仕様は6sに類似しています。シルバー、スペースグレイ、ゴールド、ローズゴールドのカラーが揃っています。16/64 GB容量、Model A1662とA1723
1050回答 すべてを表示
iPhone SE mic and other issues
I have an iphone SE that I am having issues with that I hope someone can help me with. It was brought to me to try and fix. First of all, the ear speaker will not work at all, it will not switch over to headphone mode when you plug in headphones. Siri will not pick up your voice, when you open voice memos, the record and play buttons are grayed out and you cannot select them. Also, during a phone call you can't switch it over to speakerphone because the buttons are grayed out too. However, the speaker does work to play music or videos and system sounds. I've replaced both the front camera flex cable and the charge port flex cable with the same results. Do you suppose that There are motherboard issues or is it another part of the phone that I'm overlooking?
Thanks for the assistance.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
No dought that is the fault of audio ic
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
So, is this an expensive fix? I know it involves microsoldering which I can't do. :)
さんによる
コメントを追加
回答を追加する
Ethan Grier さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 14
今までの合計 142
