メインコンテンツにスキップ
Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
179回答 すべてを表示
Radio not turning off, causing battery to drain
I have a 2003 Dodge Caravan and the radio in it won’t turn off when I turn the vehicle off. The radio makes a clicking/humming sound when it’s off and causes the battery to die after a while. I’ve tore apart the center cluster to unplug the radio and DVD player as a temporary fix and I was wanting to see if I could get some help to find a fix. Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
What is the fuse number or letter for a 2005 Dodge Caravan replacement.
さんによる
コメントを追加
1 件の回答
Your issue could be one of the following:
1) Improper head unit wiring
--If the main power wire for the head unit is connected to a power source that is always hot, the radio won't ever turn off.
Fix: rewire the radio to receive power from a source that is only hot when the ignition is in the accessory or run position.
2)Ignition switch problem
​--​If there is a problem with the ignition switch or cylinder, accessory power may be available even when the key is removed.
Fix: check to see if accessory power is available when the key is in the off position. Realign the cylinder or replace the ignition switch as needed.
3)Worn out key or ignition cylinder
--​If your key or ignition cylinder are especially worn, you may be able to remove the key when the switch is still in the accessory or on position.
Fix: make sure that the ignition switch is actually in the off position in the short term, and replace the cylinder when you can.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Camron Edging さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 28
今までの合計 5,462
