Is it possible to replace the WiFi card inside this laptop?
if so, please post a guide step by step.
thank you.
この質問は役に立ちましたか?
thank you.
この質問は役に立ちましたか?
We have just completed a guide of our own for the Wireless Network Card. Let us know if it is helpful!
Toshiba Satellite S55t-A5389 Wireless Network Card Replacement
このアンサーは役に立ちましたか?
Yes, it is possible to replace wireless card in this laptop. You can purchase a new one here.
As for a replacement guide, there is not yet one available for this laptop and I am not able to create one as I don't own this laptop. I recommend searching Google if you haven't already.
このアンサーは役に立ちましたか?
Hi
To add to this answer here is a video that shows how to open the laptop to gain access to the WiFi card (5:19 minutes into the video).
It is always advisable to disconnect the battery when working on electronic equipment to prevent any electrical problems from occurring if you slip while using tools inside the laptop. Even though the laptop is Off there is still power on the motherboard. You don't have to remove the battery, just disconnect it.
Disconnecting the battery doesn't stop "mechanical' problems though e.g. components removed from board accidentally.
Don't forget to reconnect the battery before you close up after the repair/replacement
Definable it’s possible but betting buy a wifi adopter which will do the same thing in cheaper price.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,374
