メインコンテンツにスキップ
Appleコンピューター以外のキーボード用修理ガイド
242回答 すべてを表示
When I press one key the other keys in the same row presses too.
My brother has a "Corsair K95 RGB Platinum" and he smashed the keyboard. Because of this incident I had to replace the x key on his keyboard. But after replacing the broken key with a new key, the keyboard acts out and presses every key in the row(Shift z x c v b n m , . / Z X C V B N M < > ?). Is there any way to fix this issue?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
2 件のコメント
Hi,
Was the keyboard working OK, apart from the x key, before you replaced the broken key?
さんによる
yes it was working okay, only the x key was the problem.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi,
You may have to go back and check what you did.
Pressing down on the key seems to cause a s/c on the "row" line.
Don't know your keyboard but was there any way that you may have 'reversed' the installation of the key?
Bit hard to know with an ''X 'whether it is in the correct way. Not in upside down I mean. Other letters and numbers are more obvious.
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
I don't think that I can install it the wrong way. The pins are in a specific location and the frame prevents me to install it the wrong way.
さんによる
Hi,
Does it still happen if you remove the key?
さんによる
No it does not happen when I remove the key. It only happens when I press X.
さんによる
Hi,
You may have to check for solder "bridges' when you install the key.
Did you insert the new key into the key "frame or holder' (for want of a better term) that is in the keyboard, the correct way?
さんによる
Yes I installed it in the key in the right position.
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Yong Min Jeon さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 44
今までの合計 2,076
