メインコンテンツにスキップ
A model in the Q400A series by Asus. This model features a 14" display and contains a quad-core i7 processor, 8GB of RAM, and a 750GB hard drive.
2回答 すべてを表示
Will not charge. Bought a new battery. Bought a new charger. Will not
The previous battery would not hold a charge. Laptop would work when plugged in. Then stopped. Ordered a new battery and a new charger. The new battery worked until the charge emptied out. The charger will not charge the battery. What do I do now or where do I go to get it fixed?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi @gye7293 ,
Does the laptop indicate that the battery is charging when you just connect the charger to the laptop?
If not, as it doesn't start with the charger connected, then you may have a faulty DC-In jack.
It may be faulty or it may have become disconnected from the motherboard.
Here is a video that shows how to access the DC-In jack.
Here is a link to just one supplier of the replacement part.
It is not a recommendation to use them. It is shown to give an idea of the cost of the part. There are others online that may suit you better. Just search for Asus Q400A DC-In jack part to get results.
You will need soldering expertise and tools to effect the removal (if necessary) and replacement of the part.
If this seems too daunting, contact a reputable, professional laptop repair service and ask for a quote to repair the laptop. You already know the cost of the part. ;-)
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Lora さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 5
今までの合計 270
