メインコンテンツにスキップ
2017年7月28日に発売されたNintendo 2DSの継続モデルのハンドヘルドゲームコンソールです。
203回答 すべてを表示
Why does the top screen portion wiggles back and forward?
It seems that the problem that I have with my 2DS XL system is very common across the Nintendo DS family, so I wonder if you could help me getting together a fixing kit for this issue.
I’ll be Of great interest for me to buy it along with the Pro Tool Kit.
Thanks in advance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
As far as I know, the New 2DS XL is like this from the factory. It should wobble a bit as it means its less likely to break from tension. You could try putting a small square of clear mounting tape on the back of the hinges to prevent wobbling, as done in this Reddit post: https://www.reddit.com/r/3DS/comments/8u...
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi!
This is a common issue with all DS systems as you said, but there's not real fix (or not hat I know of) other than replacing the hinge or even the casing when the wiggle gets very bad
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Yes all of the Nintendo ds series and their screens all have a little bit of Freeplay, if you don't want the Freeplay there is a 2ds that doesn't close unfortunately, but you won't have to deal with the screen wiggling back and forth.
さんによる
コメントを追加
回答を追加する
Daniel Candia さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 22
今までの合計 409
