メインコンテンツにスキップ
iPad Air Wi-Fi +セルラーモデル、モデル番号はA1475でスペースグレイかシルバーのカラーが選べ、容量は16/32/64/128 GBがあります。
125回答 すべてを表示
Can I use an A1474 main board as a replacement?
A1475 logic boards are quite expensive, while A1474 boards seem much more readily available. From my uneducated perspective, the major difference between the two is that the A1475 has a spot to hook up the LTE antennas, and I'm sure some circuitry to process it.
Can I slap an A1474 board in there and just not hook up the LTE antennas, and use the unit as a Wifi only Ipad? The reason the board is bad in the first place is the power management chip is bad (confirmed by replacing the battery and still not being able to charge).
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Yes, you can always just not connect the LTE antennas. But then, you'd just have no LTE at all, and your frame would say you had a A1475 iPad, so then you blow all chances of ever doing a Trade-In, and selling it would be a hassle to explain. But if that does not bother you, yes you can just not connect the LTE systems and use it as a WiFi iPad Air.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mark Herter さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 4
過去 30 日: 6
今までの合計 351
